Question on TPS voltage
Thank's,Carter
TB closed -- I've seen anywhere from .45 - .9, currently mine is at .6
Anyway, for my car, stock, the settings were .53V closed throttle, 4.36V WOT. After adjusting the TB butterfly to a 90* WOT angle, the WOT voltage was 4.60, as read w/a DVM through the TPS sensor.
Setting to a specific voltage is not necessarily the right thing to do,the idea here is to attain a 90* angle to incoming air to allow lesser resistance (just don't go over the voltage that trips the PO code).
As for my idle (closed throttle voltage), I have mine stepped up a little.
