Idle problems with 42# injectors
Old Jul 6, 2007 | 03:38 PM
1hotls1's Avatar
Default Idle problems with 42# injectors
With mods in sig, the car runs great at wot, but I still have some issues at idle especially when the engine is hot. Hot starting is also very difficult and it takes a while for the idle to smooth out. Right now I'm comensating with the adjustment on the tb, but what can I do to fix this?
Old Jul 6, 2007 | 08:15 PM
mr2guru's Avatar
First off, what is your current tuning solution?
Old Jul 7, 2007 | 04:07 PM
1hotls1's Avatar
It has been dyno tuned, but something isn't right in the idle. Its a decent sized cam, but I'm sure it can be better than this. My tuner uses HP tuner but has never tuned with a new fuel system and I just changed injectors, pump, intake, and tb.
Old Jul 7, 2007 | 05:01 PM
mrr23's Avatar
so, did he reset the IFR table for the larger injectors?
Old Jul 7, 2007 | 06:00 PM
Frost's Avatar
not to sound crappy, but if you don't have your own tuning suite there is nothing that anyone here can help you with, unless it's a sponsor retuning your setup.
