idle question
Old Jul 8, 2007 | 11:42 PM
FL Junkie's Avatar
Default idle question
this is kind of an odd question. when i first start my car up, it sounds really choppy and lopey, from a cold or warm start either one. i love that sound. after i run it awhile, it starts to sound smoother ...still like cam but not as choppy. why does it do this? is there anything i can tune and tweak to make it keep sounding like that all the time?
Old Jul 9, 2007 | 05:50 AM
macca_779's Avatar
less base timing, leaner mixture, and a lower RPM will get it running rough for you. Timing is the main one though
Old Jul 9, 2007 | 07:43 AM
SSpdDmon's Avatar
Exactly, initial timing is only in the low teens just after startup. You should be able to get that thing to idle just fine at 850rpm with about 23~24* of timing. Anything more and you'll get deceleration surging when DFCO isn't active.
Old Jul 26, 2007 | 05:38 PM
FL Junkie's Avatar
heres my tune if you can look at it...also having other issues...
are you talking about spark advance under "in drive, in park"? which one do i change and how much should i lower the timing?
File Type: hpt
Old Jul 26, 2007 | 05:39 PM
FL Junkie's Avatar
well the attachment didnt work try here...
http://www.hptuners.com/forum/showthread.php?t=13470
Old Jul 26, 2007 | 08:04 PM
Jasonscott's Avatar
my car did kind of the same thing. just sounded like it lost its lope after a couple minutes. mine ended up being the timing overspeed underspeed correction. that **** was rythmically jumping from like 15 to 35 degrees trying to keep the idle perfectly at 900, so I cranked the over and underspeed correction way down and it helped out alot.
Old Jul 26, 2007 | 08:31 PM
FL Junkie's Avatar
ok thanks. how far down?
