Resistor Mod Cleared me of Detonation
60 deg F air has a density of 1.22 kg/m3.
90 deg F air has a density of 1.16 kg/m3
The higher the density the leaner the charge if fueling stays the same. With that said, your car should be richer when it is 90 deg F out than when it is 60 deg F out.
If your A/F is going the other direction I would chalk it up to MAF error, O2 error, or ECT skewing.
That's still my theory at least. I've relocated the IAT to get rid of that and get a true IAT reading. Now, the trick is setting the Charge Temp Blending table correctly. That's what Marcin's working on. Hopefully, his math skills will have us an answer (procedure) to do this properly.
VE table values in GM units are specified as: g*K/kPa.
Where g = grams of air
K = temperature of air charge in degrees Kelvin
kPa = Manifold pressure
g is calculated based on the stored VE table value, K, kPa and RPM. With incorrect IAT values, K will be inaccurate, and subsequently fueling will be incorrect.
Theoretically the IAT should skew fueling +/- 6.2% (0 to 40 deg C)
With charge bias this value drops below 5% for nearly all driving conditions.
This is a drop in the bucket considering a 5 kPa change in MAP is a 7% shift in density/fueling alone.
Yes it affects it, but it isn't going drive your tune far off if your IAT isn't exactly on. Like I said, my IAT isn't even connected and I'm 3bar SD.
Air Density = (Pressure * Molar Mass) / (R * Temperature)
65 kPa @ 0 deg C
Air Density = 0.65 * 28.966 / 0.083144 * 273.15
Air Density = 0.829 kg/m3
65 kPa @ 40 deg C
Air Density = 0.65 * 28.966 / 0.083144 * 313.15
Air Density = 0.723 kg/m3
Deviation +/- = (1 -(Low / High)) / 2
Deviation +/- = 1 -(0.723 / 0.829) / 2
Deviation +/- = +/- 0.0638 --> 6.38%
Air Pressure Effects on Air Density (Ideal Gas):
60 kPa @ 15 deg C
Air Density = (0.60 * 28.966) / ( 0.083144 * 288.15)
Air Density = 0.725 kg/m3
65 kPa @ 15 deg C
Air Density = (0.65 * 28.966) / (0.083144 * 288.15)
Air Density = 0.7858 kg/m3
Deviation = 1 - (Low/High)
Deviation = 0.07692 --> 7.69 %
I tried posting a picture of a log which shows how my the a/f of the car hovers around the the target a/f of 14.2 even though the IAT is flatlined at 14 deg C. The day was an 80-90 deg F day even though the car was tuned in a 60-70 deg day.
I always connect the IAT for all of the other SD tunes that I do.
I left mine out temporarily when I first did the tune and then just left it out because oddly enough the a/f hardly even notices it being jumpered.
