Misfires that won't go away help!
Old May 15, 2003 | 07:47 PM
quickWS6's Avatar
Default Misfires that won't go away help!
I have misfires on cylinders 2 and 6 a good bit of the time. I have monitored it with Atap at idle and all the other cylinders aren't as bad. I swapped the plug wires on them to make sure I had the coil wiring right (I messed up the wires when I did a coil relocation). I still get the same thing. It starts fine and sits idling fine for about 10 seconds, then I hear loud popping. Any clues what it coule be?
Old May 16, 2003 | 12:55 PM
rumbleme's Avatar
Default Re: Misfires that won't go away help!
Try looking at the engine in the dark. I have some coil packs arcing to valve covers.
If yours is arcing you will be able to see it then.
Old May 16, 2003 | 03:49 PM
quickWS6's Avatar
Thanks for the help, but that isn't the kind of popping I'm getting. When mine begins to pop, it is loud and sounds like a coil pack wire is wrong, but I don't see how it could be.
