Cars running rich help!!
Old May 18, 2003 | 07:28 PM
chevy1322's Avatar
Default Cars running rich help!!
i have a 1998 camaro z28 i have a 85 mm mass air flow sensor from slp hypertech programmed (but i have the power tuning off) airbox,msd wires,converter,loudmouth exhuast,thats most of the things i have done to my car,it running rich you can smell raw fuel out the exaust and it spudders out the pipes but if i drive for several hours it starts to run better...maybe someone can help thanks
Old May 18, 2003 | 07:57 PM
T/A Medic's Avatar
Default Re: Cars running rich help!!
The running rich just started recently? or after a mod u did? if ur not running cats that could contribute to a fuel smell... find atap somewhere see if ur fuel trims are all jacked...
Old May 18, 2003 | 10:15 PM
chevy1322's Avatar
ihave the stock cats on it,i had these mods on there for about a year with no problem i let the car sit threw the summer i used it but not alot i took it out last week and drove it for a long while and it started running good now its strarting up again,it spudders out the exhaust and idles real ruff it is running real rich.thanks
Old May 19, 2003 | 10:48 AM
waverider's Avatar
Have you checked your 02's. They might be bad causing the pcm to dump in way to much fuel. Have the car scanned.
