LS-1 Edit tuning, does elevation matter?
Old May 19, 2003 | 02:28 PM
CAracer's Avatar
Default LS-1 Edit tuning, does elevation matter?
I'm considering having my car tuned in Las Vegas. Elevation there is approximately 2300'. The car will be used in LA, elevation, sea level. Will the tuning be correct for sea level? Would I need to have it tuned again for use at sea level?
Thanks in advance...
Old May 20, 2003 | 01:46 AM
blown 346's Avatar
Default Re: LS-1 Edit tuning, does elevation matter?
I know it will make a difference, the air is thinner so i would think that it will make a difference.
Old May 20, 2003 | 01:38 PM
Cal's Avatar
Cal
You should be OK doing that, in theory at least. The PCM automaticaly adjusts for elevation.
