Which tune is best
Old May 20, 2003 | 12:13 PM
TunerWannaBe's Avatar
Default Which tune is best
Which tune would be best for me. (Note: Both tunes with ported maf & SVO 30's)
Tune A:
Install ported maf & only adjust my Injector Flow to lie to the PCM about being lean and gain more timing.
or
Tune B:
Install stock maf, adjust Injector Flow according to the stock maf. Once Injector Flow is completed, install ported maf and adjust maf table to get values back in line.
Which tune would be better, A: lie to the pcm or
B: Actually re-calibrate maf sensor functions.
Old May 20, 2003 | 01:36 PM
Cal's Avatar
Cal
Default Re: Which tune is best
I would say adjust the IFR table to compensate for the SVO 30's first, then install the ported MAF and adjust the MAF table.
Old May 20, 2003 | 07:54 PM
That's what I think also. Everything I'm reading though pretty much says if I lie to the pcm adjusting my "too rich condition" Injector Flow to be lie about being lean, I will gain more timing etc. and overall gain more performance out of this tune. *(Ported maf Injector Flow adjusted only)* Any other feedback on this????
Old May 24, 2003 | 07:01 PM
TTT
