slangin' codes
Old Aug 6, 2007 | 07:44 PM
ZTwentyAteU's Avatar
Default slangin' codes
I noticed the other day my trans am SES light does not light up when key turns over, so I got curious and scanned it. I guess someone took the bulb out(idiots)
410
412
418
they are all "secondary air injection system malfunction" codes
Is this the AIR pump????
Old Aug 7, 2007 | 01:35 PM
2001NBMZ28's Avatar
First step in the diagnosis charts for each of those codes is to check the AIR PUMP fuse for an open. Start there and replace the fuse if it's blown, if it blows again you'll have to look further.
Old Aug 7, 2007 | 03:47 PM
98inconTT's Avatar
Mine is throwin the same codes except P0410. Its only P0412 and P0418 but they always come on simultaneously. I checked the fuse and its ok..changed the relay, and the drivers side check valve but no luck. I've heard it's usually one of those three but it's not working for me. Anyone know of anything else it could be?
Old Aug 7, 2007 | 04:02 PM
2001NBMZ28's Avatar
Visit gearchatter.com and look them up individually for your year.
Old Aug 8, 2007 | 01:10 AM
I had a pump go out on a 2000 S10 and I replaced it. Our cars have the electric pump i presume.
