Car backfires on cold startups
Old May 22, 2003 | 01:39 AM
quickWS6's Avatar
Default Car backfires on cold startups
Is there any way to tune out a car backfiring on cold startups? Thanks!
Old May 22, 2003 | 04:40 PM
2000SSNB's Avatar
Default Re: Car backfires on cold startups
Hello,
I had this problem and it is now mostly resolved.
I used custome programming after a cam change and cold
idle was way to rich. So I asked the programmer to change
the richness level of the cold start idle to leaner
by about 5% or so. I first tested thsi with the MAFT
but of course this will also lean out under all other conditions.
Gert
Old May 23, 2003 | 01:25 PM
highgear's Avatar
Mine only had a "burp" when I cracked the throttle on cold starts.
Leaving throttle closed cured it.
Old May 23, 2003 | 02:52 PM
quickWS6's Avatar
Mine won't crank without some throttle, guess I need to drill the TB hole more. I think it is just really rich, I leaned it out some and it seemed to help. If I can just figure out why my banks are running such different A/F ratios I might be okay.
Old Jun 1, 2003 | 05:34 AM
LS1derfull's Avatar
My car does this also on cold mornings, i feel its caused by air pump running and dumping into cat-less exhaust.This may not be only reason but its got to be contributing to it.
Old Jun 1, 2003 | 08:12 AM
Assassin's Avatar
your exhaust is wide open and you need to get a new timing chain, the slack in the chain will cause it to spark when exhaust valve is opened!
Old Jun 1, 2003 | 09:26 AM
quickWS6's Avatar
I don't have an AIR pump and my timing chain is a brand new double roller Rollmaster.
