had a close call with ls1 edit crash
i did a control alt delete to end the program. i shut down the computer and restarted it
i then restarted ls1.prog and without ever turning the car off or unhooking the cable i started the write of the same file over.
it worked! everything is fine.. just fyi if you are ever in the same situation.
i have done over 30 edits so far on my car and this was the first time it had happened.
if that happened. I've got 3 edits without any incidents so far.
