Torque management
Here's how to disable it (from ls1edit.slowcar.net):
1. Go to transmission -> A4 Shift Firmness -> Torque reduction and zero out the table
2. Trans Cal -> A4 Shift Firmness -> Upshift Torque reduction - zero out the values
3. Engine -> Ignition -> Max Torque. Set it to 1000
4. Engine -> Ignition -> Torque Reduction. Zero it out.
One other item to mention is that I've seen discussions centering around the Max Torque setting. Ken (from Carputing) stated that the max value shouldn't exceed 639.
