weird problem
Old Aug 16, 2007 | 01:01 PM
Art Vandaley's Avatar
Default weird problem
not sure if you guys can help diagnose this problem or point me in the right direction. but i noticed that last week i let the car sit for a week in the garage.. i went to fire it up and the needles reset them self (pegging and then coming back) also the trip resets it self. okay i let the car sit for a week. i drove the car yesterday parked it in the garage, went to fire it up today and it did it again.. reset itself.. trip and the needles pegged and went back to normal. sorry for run- on sentences. anyone? thanks in advance.
Matt
Old Aug 16, 2007 | 01:11 PM
00ssmg's Avatar
Sounds Like A Poss. Body Control Module Problem
Old Aug 16, 2007 | 01:25 PM
2001NBMZ28's Avatar
The '99 cars do that when battery voltage is low. GM issued a TSB on it to replace the gauge cluster but a new/good battery usually takes care of it.
Old Aug 16, 2007 | 01:33 PM
hmmm now that u mention it.. when i tried to start it sounded a little weak. i just replaced the battery 2 weeks ago. something must be killing the battery or defective?
Old Aug 16, 2007 | 02:49 PM
wait4me's Avatar
The factory alarm does use voltage and will eventually drain a battery when sitting.
Old Aug 16, 2007 | 03:44 PM
even if its not armed? i never arm it when it sits in the garage.
Old Aug 16, 2007 | 04:49 PM
2001NBMZ28's Avatar
Well there's always some drain, even with the alarm off. If you want to eliminate the battery as the problem bring it back and have it load tested.
