can i get some help with my diablo
Old Aug 20, 2007 | 04:11 PM
m-knight's Avatar
Default can i get some help with my diablo
i have a trans am ram air 2000, and i want to tune it with my diablo , so please can someone help me with the tuning or can i get an expert e-mail.
please.
the car has the following parts:
edelbrock short headers.
kit back corsa
air system with slp filter.
and how to program the pinion i have 3.73 and i will change it to 3.42
and how to increase the horse power by the predator.
and i will appertiate any help i can get.
Old Aug 20, 2007 | 04:39 PM
02m6's Avatar
you need to look at your LTFT and adjust your injector slope. Make sure there are not any positive numbers on the LTFT. I have mine at -5 at part thottle. When you hit WOT the LTFT should be at 0. To adjust you injector slope, example if you are at +10 then adjust the injector slope -10. Its that easy. You can also look at you what you 02 sensors are reading should be around 900 at WOT. IF its low,adjust the power enrichment up some to get the number up. I would not play with the timing.
Old Aug 21, 2007 | 01:30 PM
m-knight's Avatar
thank for your help 02m6 but can i ask you which car you own, thanks again
Old Aug 21, 2007 | 04:27 PM
02m6's Avatar
I own a 02 trans-am WS6 with the 345hp slp option
Old Aug 22, 2007 | 10:28 AM
thunderdan74's Avatar
Check Diablosport's forum. You may have to send the Predator off for an update to be able to re calibrate the speedo for new gears. FYI
Old Aug 22, 2007 | 10:58 AM
sprayjunkie's Avatar
It actually sounds like he is going from 3.73s to 3.42s, so unless the PCM has already been tuned for the 3.73 gears, no changes should be required.
Also, do you know if the PCM has been tuned in the past?, as you should not apply the Diablo tune to a tuned PCM.
Old Aug 25, 2007 | 09:18 PM
z2fast8's Avatar
hey can i use someone elses diablo to tune my car he said something about it be'n vin locked?
