Computer died?
Old Aug 22, 2007 | 01:27 PM
402CAMAROSS's Avatar
Default Computer died?
I was doing some mock up with my intake this morning, got everything back together. I get in the car to start it and it spins over, but no start. First I noticed the odometer is blank,not showing 0000 but totally blank. Then I checked for fuel pressure, zero, not a little, zero. Noid light says no signal to the injectors and no fire from the coils. . I took the intake back off to look for any pinched or loose wiring but didnt see anything. As far as I can tell I didnt break anything and I took my time doing this. Are there any connectors behind the intake to check? I did plug the map sesnor and vacuum hose back in as well as maf, idle control, intake temp, blah blah back up. I didnt even disconnect the fuel lines as I just needed a measurement.
Old Aug 24, 2007 | 05:55 PM
Stupid ground wire.
