need 96 lb injectors, WOW
Old May 26, 2003 | 06:39 PM
scottywheels's Avatar
Default need 96 lb injectors, WOW
Well in preperation for bowlng green we had to upgrade the fuel pump and go to billet aluminium rails. With these upgrades Im seeing 21 psi with the F1. I made a little over 600 rwhp through the T400 and 12 bolt at 5400 rpm. I ran out of injector so we had some 96 lb injectors over nighted to get to cartek on tues. Then tuning and on the trailor for bowling green. Hopefully Ill get another 40-70 hp going to 6800 with anough fuel. I also changed the gears to 3.55's.
The Reichard Racing Pulley that I run is awesome, Im getting no slip on the 4.50 pulley.
hopefully see some of you at bowling green.
Old May 26, 2003 | 06:55 PM
WICKED SS's Avatar
Default Re: need 96 lb injectors, WOW
Damn thats crazy!
What size motor you running and what kind of pistons, rods and crank?
I wonder what size I am going to need after I add my heads and the 100-150 shot?
Old May 26, 2003 | 11:14 PM
I have a stock cube 346, with JE pistons, lunati rods, nitrated crank, 9.2-1 Comp,cartek heads, comp cam, FAST engine management system,ati F1 procharger,T 400 tranny, moser 12 bolt 355 gears.
