98 Corvette wanting 99 computer
Old Sep 1, 2007 | 08:22 AM
99T-Top Z28's Avatar
Default 98 Corvette wanting 99 computer
I was just curious if I can do this. I have a 98 corvette and I was thinking of buying a 99 TA computer and engine harness. I'm putting in a 408 and while motor was out I figured it would be pretty easy to just install the 99 harness and pcm. Will this work or is there more to consider.
Old Sep 1, 2007 | 09:50 AM
MorePowerPlease's Avatar
Do you have a 98 or 95?? If you have 98 go onto the corvette forum and do search. There was a guy that did this not to long ago. He just switch the pcm. Its all about redoing the pin setup. The guy said he did it in an afternoon with a buddy. Looks easy just have to label all wires as you pull them out and replug in to the new conncector.
Old Sep 1, 2007 | 10:04 AM
He posted that on here too...I read it...But if Im already going to have the motor out would be a lot easier and fool proof if I can get away with just changing entire harness. I have a 98 C5, and im getting a 99 TA harness and computer.
Old Sep 2, 2007 | 12:15 PM
Patrick G's Avatar
LS1 Tech Administrator
Moved from advanced tech section.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Sep 2, 2007 | 07:27 PM
slow's Avatar
you will need the harness from a vette, since the TA does not have drive by wire. I woudl just do the pin swap, and personally, if possible, I would do this swap, before you pull the motor out of the car, (much easiler to troubleshoot if there is an issue)
Ryan
Old Sep 2, 2007 | 08:59 PM
Doc's Avatar
Doc
I'm the buddy. And I have done this multiple times with different applications/resources.
It is easy if you use your exisiting 98 vette harness. Very difficult if you try to employ the Fbody harness. For starters the vette harness is physically the right length to do this endevor- the Fbody is going to come up short. As mentioned before in this thread, the drive by wire characteristic is going to be a issue as well. The shortest distance btw to points is a line, take it. Measure twice, cut once.
Old Sep 3, 2007 | 12:28 AM
Ok I will just repin will the 99 ta comp be fine to run everything
Old Sep 3, 2007 | 09:14 AM
Eurospec2's Avatar
it will have to be re-flashed with a corvette operating system using EFI Live, but yes physically it will work, pm me if you want info on what you have to do for tuning
