please help with codes be thrown
Old Sep 3, 2007 | 07:16 PM
turbo408stroker's Avatar
Default please help with codes be thrown
i installed a hp turbo kit its a gt45r 75 lbs injectors with magnafuel pump on my 408 stroker now that i got it done i have codes being thrown here they are
U1301 - Class 2 Short to Battery
U1016 - Loss of Class 2 Communication with VCM
U1040 - Loss of Class 2 Communications with ABS
U1096 - Loss of Communications with IPC
and a camshaft position sensor circuit high and low
when i delete the codes all come back immediately. except for the throttle position sensor. when i start the car it runns good for hte first ten seconds then my tach drops down and the cam shaft position sensor circuit high and circuit low come back. i have checked all fuses and wires and all grounds. please help thanxs
Old Sep 3, 2007 | 08:46 PM
ZL1Killa's Avatar
howd u tune the 75lb/hr injectors??
u need to get some stuff fixed son, somethings wrong ... take it to the shop that did it or check all your sensors and wires again...replace sensors..maybe something broke... thats about all i can tell ya
