LS1 Edit Question *DELETED*
Old May 29, 2003 | 05:13 PM
Tim 98z's Avatar
Default LS1 Edit Question *DELETED*
Post deleted by Tim 98z
Old May 30, 2003 | 12:23 AM
Tim 98z's Avatar
Default Re: LS1 Edit Question
Can't believe no one has any info.
Old May 30, 2003 | 12:38 AM
ngozer's Avatar
i know how you feel about not many people putting posts sometimes when you really need info. i dont know much about it but i would think you would have to pay the 150 (i think) to unlock the new pcm for edit.
Old May 30, 2003 | 08:03 AM
Windy City's Avatar
You post that you have a LS1 Edit question but then ask if a 2001 PCM will work on a 2000 vehicle.
To answer your question, no it will not work 100%. The 2000 vehicles still had EGR so for starters, he'd trip a SES. In addition, the cam specs are different between the years which affects the timing tables. The 2001+ cars didn't need as much timing. I've run a 2000 timing table in my '02 Z28 without any issues though.
Now all this can be corrected with LS1 Edit, such as turning off the EGR system but he'll then need another PCM license to edit the 2000 PCM as is and the VIN won't match. I suggest he take it to a dealer to be reflashed to 2001 code and his VIN. He can use the PCM to get him to the dealer as is.
Old May 30, 2003 | 10:54 AM
Tim 98z's Avatar
double post
Old May 30, 2003 | 10:55 AM
Tim 98z's Avatar
Well that explains that it will work. The cam is not stock for either car so the timing tables have to be tuned anyhow. Egr Who has that crap anymore?
