MAP/TPS codes simultaniously
Old Sep 13, 2007 | 01:04 PM
ba78ta's Avatar
Default MAP/TPS codes simultaniously
[PCM] P0106 - Manifold Absolute Pressure (MAP) System Performance (SES) (Old) (History) (Immature)
[PCM] P0121 - TP Sensor Circuit Insufficient Activity (Old) (Immature)
The car has a fast, and I've searched that you have to raise a parameter relating to the map... however... why would it be throwing the TPS code? It has done this on more than one occasion, and then seems to clear itself out
Old Sep 13, 2007 | 01:13 PM
foff667's Avatar
LS1TECH Sponsor
This should help explain things better http://www.hptuners.com/forum/showthread.php?p=101510
Old Sep 13, 2007 | 01:52 PM
ba78ta's Avatar
well there we go. thanks!
