What could be the problem?
Old Sep 18, 2007 | 03:25 PM
letsrun97z's Avatar
Default What could be the problem?
on sunday
finished installing the plugs earler had to replace wires too but only had time for the pass side when we started it up it was shaking we had 4 and 2 mixed swaped and idled fine but smells really rich, we took it for a drive and i was making a noise i couldnt track down but i did noticed top end was pulling like a somagun.. i thought i head knock but wasnt sure, i cruzed to my girls house normal, just now its dark i got on it and i heard the knock at low rpm then went awayhigher up looked in the rear view smoke everywhere parked it.. question is would not replacing the driver side wire's make it do that? nothing else was changed ngk tr55 @.050 i was going to put the other wires one this weekend and leaved it parked till then anyone know what could be up car is all stock 97z Lt1
just now
well i had it scanned by a friend using http://buy1.snapon.com/products/dia...iewer.asp?id=97
that same snap on scanner and it said that the maf is whats making it run rich i dont know if it means anything but idle was 1.50-1.20v back and forth?? im going to spray it out with the cleaner
Old Sep 19, 2007 | 01:01 PM
letsrun97z's Avatar
any help or advice please I have a code p0108 for map sensor I replace it last night drove fine for a little bit never got it above 3k then it threw the code again shold I be lookming into a new maf now
