2002 Z28 PCM and a 2003 LQ4 engine
Old Sep 20, 2007 | 09:57 PM
93Z28rare's Avatar
Default 2002 Z28 PCM and a 2003 LQ4 engine
Will these two items work well or will I need a 2003 LQ4 PCM? If these two items do work well together, the tuner I get for the PCM should be based on the 2002 OBDII PCM or the 2003 LQ4 engine? Thanks.
Carlos
Old Sep 21, 2007 | 01:12 AM
01WS6/tamu's Avatar
You can have the fuel air and spark tables written over the 5.7 tables and it will be fine. If you use the 5.7 programming you can keep a cable throttle body. What it's going into determines a the outcome of the answer you will get here.
Old Sep 21, 2007 | 09:12 AM
minytrker's Avatar
Anyone with EFI Live can make you a tune with your transmission calibrations and a LQ4 calibration for the motor. So you would have a stock LQ4 tune and your transmision tune as your base tune. No hand coping and pasting needed.
Old Sep 21, 2007 | 06:06 PM
93Z28rare's Avatar
It's already in a 94 Camaro.
