EFILIVE speedometer problem
Old Sep 22, 2007 | 05:05 PM
mrialsm4's Avatar
Default EFILIVE speedometer problem
I'm programming with EFILIVE.
I have an 06 GTO, I'm trying to recalibrate my speedometer. I swapped the 3.46 gear for a 4.56. I have changed the following tables in my ECM and TCM, with no effect on the speedometer reading.
ECM-
H0101
H0104
H0103
H0122
H0125
TCM-
H0101
H0103
Also, all of the shiftpoints have been adjusted in the transmission according to the EFILIVE tutorial.
I have changed these parameters from one extreme to the other and back again, I've been at this for several hours. There HAS to be something that I'm leaving out somewhere, because no matter what I change the values in the tables above to, the Reading is still 75MPH @ 2400RPM, when it should actually read betwen 50/60MPH.
Somebody help me, as I only have a few hairs left to pull off before there's none left.
Thanks-
Mike
PS- I'll add that I'm also running the GEN IV 2bar OS. If it's of any consequence.
Old Sep 22, 2007 | 05:28 PM
mrialsm4's Avatar
anyone?
Old Sep 23, 2007 | 12:47 AM
mrialsm4's Avatar
ttt ttt
Old Sep 23, 2007 | 04:23 PM
mrialsm4's Avatar
ok, here's the response I got from EFILIVE-
There are issues with the speedo calculator.
Some vehicle/controller combos are not supported by the speedo calculator. in the EFILive software. We are working on figuring out why some controllers do not respond as expected to changes in the calibrated values.
We expect to have an improved speedo calculator in the next software update, which is due for public release before end of October.
Regards
Paul
Does anyone know of another solution?
