Predator Tuner and P0757
Old Sep 24, 2007 | 01:55 AM
93Z28rare's Avatar
Default Predator Tuner and P0757
I wanted to know if the Predator tuner could completely delete the test for solenoid B. I get the P0757 code and I'm pretty sure it's because I have a Yank 4200 stall converter. I don't just want to clear the code, I want to remove the test that sets this code.
The computer is an OBDII out of a 2002 Camaro Z28. Will the tuner I get correspond with the OBDII PCM or the engine I have in my car. The engine is a 2003 LQ4. Thanks.
Carlos
Old Sep 24, 2007 | 11:18 AM
sprayjunkie's Avatar
Not sure if this is possible, but I'll check it out for you.
You would need the u7198 if using the stock PCM for the 02 Z28.
Old Sep 24, 2007 | 09:39 PM
93Z28rare's Avatar
Thank you.
Carlos
