How does the ECM figure which piston is at TDC?
Old Jun 3, 2003 | 05:16 PM
mastrdrver's Avatar
Default How does the ECM figure which piston is at TDC?
How does the ECM combine the CKP signal and CPS signal to figure out which pistons is coming up to be fired?
Thanks
Jeremy
Old Jun 3, 2003 | 07:40 PM
Bink's Avatar
Default Re: How does the ECM figure which piston is at TDC?
Reluctor wheel on the Crank signals position of crank and IDs both cylinder# and piston position. Camshaft reluctor wheel signals Intake(combustion) or Exhaust stroke. Engine will start without cam sensor- Crank signals the cylinder and the ECM/PCM randomly selects-intake or exhaust.Hope this helps some.
joel (Bink)
Old Jun 4, 2003 | 08:53 PM
eallanboggs's Avatar
B&B that sells AutoTap also markets a CD that will explain every sensor on a modern engine and explains how OBDII works as well. Check it out.
