What should I look for?????
Old Sep 24, 2007 | 01:39 PM
BadgeZ28's Avatar
Default What should I look for?????
recently finished adding a supercharger (5psi) and 42 pound Ford Motor Sport injectors. Mail order tune by PCM for Less. MAF is on the intake side and relocated in the front fender. I am getting odd idle. When it comes off cold and settles at 700 rpm it surges like the lope of a cam. I also get some surging higher in idle rpm when it is cold. I went to start it the other day and it wouldn't hold a idle. I popped the hood and took a look around and everything seems ok, so I tried it again and it ran. No SES codes. I have limited scanning ability. What do you suspect might be the problem? Thanks
