Base 96lb Low Impedence Injector Program??
Old Sep 25, 2007 | 07:08 PM
Mike Norris's Avatar
Default Base 96lb Low Impedence Injector Program??
I have a customers TT car with a base tune and using HP Tuners in it that is running 96lb Delphi injectors and an Acceleronics low to hi impedence switch. It seems I can not get the injector flow low enough to lean the car out at idle. I have tried doing crazy number changes to the MAF, VE and IFR tables just to see what I get and the only time I can get an idle AF off the 10.0-1 area is by lowering the fuel pressure to 35psi. I seems like the injectors will not flow as little as needed.
I had checked the repository with no luck. Just looking for a little help. I am actually on the dyno now at 8PM and you could call if you want at 407-616-2518. Thanks.
Mike Norris
Old Sep 25, 2007 | 07:17 PM
camarols1's Avatar
I just sent a copy of a 96LB tune to the e-mail address in your sig.
Jim
Old Sep 25, 2007 | 09:06 PM
Thanks for the e-mail and I also recieved a couple phone calls. I think we are on the right track and I very much appreciate the info from everyone. I will try to update this tomorrow. Thanks again.
Mike Norris
Old Sep 25, 2007 | 09:21 PM
LS1curious's Avatar
Your welcome Mike.
Old Sep 26, 2007 | 09:10 PM
vaticano's Avatar
is this a difficult task? i will be upgrading to this type of set up as well, within the next two weeks. i still have to get the double pump as well. that may take a little longer.
Old Sep 27, 2007 | 01:34 PM
Gold Phoenix's Avatar
MY LTFTs were always saying that they are pulling fuel out at idle, but after a couple days on the tune the PCM seems to lean it out for me. I know if I try to go too low on the VE table, I get a lean stumble.
