Alarm System Malfunction??
Old Sep 26, 2007 | 07:05 PM
T-56SLPSS's Avatar
Default Alarm System Malfunction??
My alarm system is screwed. If i lock the car by hand (not the power locks) the system will not go off. I can use my remote or power locks to lock the doors but after doing this for about a day the alarm will go off about 20 sec after i lock the doors. If i dont use the remote for a few days i can use it again but after using it for awhile it will start to go off 20sec after locking it. I thought the battery in the remote might be going bad so i changed it but i still have the same problem. Any ideas?? Is this because i leave my fuzz buster pluged in?? Thanks
Old Sep 26, 2007 | 07:35 PM
2001NBMZ28's Avatar
Never tried it - but think if you lock the doors manually (no fob/door buttons) it doesn't arm the alarm? Alarm going off just after arming for no apparent reason is usually the shock sensor taking a dump. Try disconnecting the shock sensor for a couple days, arm it to see what happens.
Old Sep 26, 2007 | 07:44 PM
T-56SLPSS's Avatar
it doesn't do it all the time only if i use it frequently then it will. Ill check that
