LS1 limit
Old Jun 5, 2003 | 06:53 PM
RacingJason's Avatar
Default LS1 limit
Anyone know the outer limits for the factory electronics? I have a customer and no matter what they do it will stop (like it hit a brick wall type of stop) at 1011 ft/lbs of torque t the rear wheels. The curve (if you can call it that) is almost vertical until it hits 1011 and then makes a 90 degree and stays at 1011. They tried some other cars on the dyno and it is fine. I know the turbos are maxxed out big time but this is ridiculous. Anyone know something they are missing here? I am damn curious as to what is going on in there. Oh yeah it is a lingenfelter program running right now in a stage 4 427LS1 Lingenfelter.
Old Jun 6, 2003 | 01:10 PM
red ws6 99's Avatar
Default Re: LS1 limit
The stock computer will max out at 512 g/s of air flow. After that it has no idea what flow you have. From the numbers you posted, you maxed that out a long time ago. Your post is very vague so its hard to figure out what your asking.
Gary
Old Jun 7, 2003 | 01:31 PM
Jpr5690's Avatar
geeze id just be happy with 1011 pounds of tq. i have no clue of your problem but id think if your spending that much in peformance ud wanna get a better computer to control it all (imho)
Old Jun 7, 2003 | 06:54 PM
The Dragon's Avatar
I'd have to agree with the above statement.
Also, as was already mentioned, more details would help
Old Jun 7, 2003 | 07:13 PM
SStrokerAce's Avatar
Post a chart of the run first. I have a feeling if it's a low RPM run it could be maxxing out the dyno.
