maf code
Old Oct 4, 2007 | 06:39 AM
pphilli1's Avatar
Default maf code
I keep getting a maf code po102 I believe is the code.It says low input
voltage & another for high input voltage.Maf was replaced about 2 weeks
ago.Someone suggested it could be a ground possibly but they are all
good-vehicle is 2000 ws6 with an LS2 402.The codes were there prior to replacing the MAF.Any ideas?
Old Oct 5, 2007 | 08:53 PM
m_williams's Avatar
bump for more info
Old Oct 6, 2007 | 07:38 AM
pphilli1's Avatar
Originally Posted by m_williams
bump for more info
driven vehicle with maf code still active but no drivability
I guess the low input/high input is confusing me.I was also told
that a racing idle can cuase this code,which mine does prior to warming
up.Its off to the tuner next week so I know he can resolve it,but I'm
curious.Any ideas?
Old Oct 6, 2007 | 10:30 AM
2001NBMZ28's Avatar
Maybe it's an electrical issue - check for an open ENG SEN fuse. Friend of mine had a melted 02 wire and it threw P0102.
Old Oct 8, 2007 | 02:16 PM
pphilli1's Avatar
Found a slight air leak at the MAF
Cant seem to find a good silicone 90tb to stock MAF adapter
The code has not come back
