headlites
Old Oct 6, 2007 | 08:35 PM
harnick3's Avatar
Default headlites
98 ta with auto headlite's. They want to come on in the garage when I start the car only to go off after I back out. How can I eliminate the auto headlite part or cure this problem? Thanks
Old Oct 7, 2007 | 03:21 AM
Rede's Avatar
Try this:
https://ls1tech.com/forums/showpost....21&postcount=6
They go on and off automatically based off of the amount of light outside. Its darker in your garage, so naturally they come on when you park, or go off when you exit durring the day.
I suppose you could do your own addition to cutting the wirebehind the switch and just wire a second switch under the dash...
That why you could run with just the park lights, yet still retain stock function at the flicka da switch.
At least I think it would work...
Then again I'm no electrician or Fbody guru.
My LS1 kung-fu is week
