At the track troubles..
Old Oct 7, 2007 | 08:26 AM
nikon1999's Avatar
Default At the track troubles..
Well had the car setup in SD mode, did some logging/adjusting for about 4 days on the street and everything was pretty good, a/f was a little rich at 12.5 but i figured better safe than sorry. Wanted to get to the track before it closed for the season and had some issues...
When i got into the burnout box and stabbed the throttle the car spiked to
20:1 afr and would NOT spin the tires never did that on the street. Was getting knock retard, but found my new y pipe to be hitting the floor so i desensitized the sensors. My timing only seems to be about 23-25* out of the whole when im calling for 28* ? After a little richening of the lower ve the car would spin the tires, but still spike to 17:1 afr when i first got on it.. (idle was awful w/so much fuel) This seemed to kill my afr in 1st gear as it was mid 13's..come 2nd - 3rd gear it was right around 12.8...
Any thoughts would be appreciated, i know i threw a lot out there, i'll post up some logs when i get home tonight.
Old Oct 7, 2007 | 08:31 AM
SLP4CamaroSS's Avatar
you got hptuners? send me your tune so i can look at it. the spark problem might be in your iat spark
Old Oct 8, 2007 | 07:46 PM
nikon1999's Avatar
you are refering to the IAT Spark Base table? Shoud i zero that out.
Old Oct 8, 2007 | 10:01 PM
Doc's Avatar
Doc
Originally Posted by nikon1999
... but found my new y pipe to be hitting the floor so i desensitized the sensors.
Fix the Y pipe, the knock sensors are merely doing their job
Old Oct 9, 2007 | 12:05 AM
Frost's Avatar
low timing at launch (hard throttle transition) can be from lots of places; your burst knock tables being one place. Also log your knock learn factor and see what happens during the launch. You probably spin through on the street.
Old Oct 9, 2007 | 05:26 AM
nikon1999's Avatar
yes i understand i need to get the ypipe fixed, im going to install some poly mounts and see what that does.
Even after i turned off the sensors though, i still wasn't getting full timing, thats what perplexed me. I will try that next time out frost. Thanks
Old Oct 9, 2007 | 09:58 AM
Frost's Avatar
sure... burst knock detection comes comes from monitoring delta airflow, not a sensor. Check that table. Zero it out for testing if you'd like
