I have an Edit MAP question :)
Old Jun 7, 2003 | 06:36 PM
The Dragon's Avatar
Default I have an Edit MAP question :)
What does this represent, why does one modify it, and how does one go about modifying it
Thanks!
Old Jun 8, 2003 | 03:40 AM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Default Re: I have an Edit MAP question :)
Not sure what you are talking about. The MAP is a sensor (manifold absolute pressure) you log in atap or efilive. It tells how much vacuum the intake manifold is under, somewhat related to throttle position but also affected by rpm and outside air pressure. It's used in most of the fueling tables.
Old Jun 16, 2003 | 05:58 PM
The Dragon's Avatar
Thank you
