maft
Old Jun 8, 2003 | 01:05 AM
muscleSS00's Avatar
Default maft
does the maft help adjust for bigger injectors?
Old Jun 8, 2003 | 06:00 PM
Predator's Avatar
Default Re: maft
I don't think it was designed to adjust for bigger injectors, but to tune your MAF. Maybe if you just swapped 26ers for 28s you might have enough adjustment available depending upon how skewed your LTFTs were to begin with. The way to adjust for larger injectors is the Injector Flow Rate table that can be accessed with LS1 Edit. Anyone else care to chime in?
Old Jun 10, 2003 | 09:23 PM
WS6 GreeN's Avatar
Default Re: maft
Sounds like you pretty much covered it.
