Please Help with Interpreting Numbers!
Old Jun 8, 2003 | 11:37 AM
IRVINEWS6's Avatar
Default Please Help with Interpreting Numbers!
Please look over this log file and tell me what you think?
I keep getting multiple misfire codes and lean condition in both banks 1 and 2.
Log File in Excel format
http://members.***.net/honez1/Files/...0mph%20run.xls
Old Jun 8, 2003 | 03:41 PM
Predator's Avatar
Default Re: Please Help with Interpreting Numbers!
First thing, you need to get your LTFTs slightly negative with a MAF Translator or LS1 Edit. The Granatelli MAF isn't helping I don't think; I would put the stock MAF in and richen the LTFTs, then you can worry about the O2s and PE/WOT a/f ratio.
Old Jun 8, 2003 | 03:55 PM
IRVINEWS6's Avatar
How do I get my LTFT's negative? I do not have LS Edit, but I do have EFI Live V5, so I can make changes while plugged in.
Thanks
I will change my MAFS back to stock.
Old Jun 8, 2003 | 05:52 PM
Predator's Avatar
The only way I know to make permanent changes to your pcm is either a MAF Translator, a Predator, or LS1 Edit. EFI Live is a diagnostic tool that I thought could make temporary changes only. Correct me if I'm wrong. The MAFT has a base (LTFT) and a WOT setting; LS1 Edit has tables that you edit; for example, MAF table, Injector Flow Rate, and PE vs RPM (Power Enrichment).
I think you need to decide if you want purchase one of the editing tools I mentioned, or have someone tune your car for you. I swear by LS1 Edit, although it takes quite a bit of research to figure-out what you're doing. The Predator is more user friendly but is limited compared to Edit. If all you need to do is just adjust your LTFTs and PE/WOT a/f, why don't you just get a MAF Translator.
Old Jun 9, 2003 | 12:06 AM
Honez's Avatar
James we were in such a hurry I forgot to tell you yesterday when we looked at your MAF sensor, we should change it back to stock and do the runs again. I know it can be contributing to your problem.
Old Jun 9, 2003 | 11:15 AM
IRVINEWS6's Avatar
Yes, your right. Tonight I am going to put the stock MAFS back on.
Like I said, last time I went to drag race, I had changed the MAFS to see if it would help my times, and then I forgot to put the stock one back on
Tonight I will change the MAFS and then do some more logging.
