installed a cam and having problems
Old Jun 8, 2003 | 06:54 PM
lthl_ls6's Avatar
Default installed a cam and having problems
I have comp cams 224/224 567/567 @114 and the dame car just keeps dieing on me when I put it in gear. I have auto 99 SS with all the boltons. Should I spend the money and go with the LS1 edit.
Old Jun 8, 2003 | 08:48 PM
TaTommyWS6's Avatar
Default Re: installed a cam and having problems
Personally, I don't know how anyone could start modding their engine (especially internally) and not have a means of reprogramming their computer.
Definitely go for LS1Edit, but don't forget a logging program. I use the scanner from obd-2.com It is the least expensive I've found, and does everything....
Good luck!
Tommy
Old Jun 8, 2003 | 09:00 PM
nevrenuf's Avatar
well, without programming capabilities, you are left with the hole in the TB solution for the problem you have..
Old Jun 8, 2003 | 09:23 PM
dand35th's Avatar
just try to turn the throttle blade screw a turn to open blade...Tahts a quick fix
Old Jun 9, 2003 | 09:50 PM
lthl_ls6's Avatar
thanks, But i think Im going to MTI to get it done
Old Jun 10, 2003 | 10:35 AM
Cal's Avatar
Cal
I'd say buy LS1edit. If you take it to MTI, you will have to take it back to them everytime you need to make another adjustment.
