help
Old Oct 12, 2007 | 11:20 PM
slolt1's Avatar
Default help
14.62857, is this high for the stoich afr. i got my hp and that is what is says if that is high how would i change it, and what does it need to be the car is running bad rich it will burn your eyes at idle
Old Oct 13, 2007 | 05:02 AM
Frost's Avatar
Leave that number as it is.... it's not what you need to be changing.
Old Oct 13, 2007 | 08:52 PM
slolt1's Avatar
ok thanks for the help i AM just trying to keep from screwwing some stuff up
i have a check engine light on and i am trying to fiqure out what i have to do to get it out
Old Oct 15, 2007 | 06:44 PM
Shallow Bay's Avatar
What code(s) is/are your car throwing?
Old Oct 15, 2007 | 09:36 PM
DaveX's Avatar
You can't go by smell, especially if your car has no cats. Mine smells terrible but the AFR is correct. So you need to hook up a wideband and see what your AFR actually is. This is where you want it for "normal" driving and at idle, unless you have a seriously large cam. Changing it won't correct your AFR, you have to adjust elsewhere to get it to this number.
Old Oct 16, 2007 | 10:04 AM
slolt1's Avatar
thanks the codes i am getting is a p0102,po412,po418 and there is one for the fuel level and cooloing fans.
thanks for the help
