Need a good MAF file
Old Oct 16, 2007 | 05:35 PM
cyclerage's Avatar
Default Need a good MAF file
can anyone email me a good MAF file for a 85mm MAF?
cyclerage23@yahoo.com
thanks
Old Oct 16, 2007 | 05:53 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
stock map file?
Old Oct 16, 2007 | 05:57 PM
cyclerage's Avatar
sure, I can probably work off that.
thanks
Old Oct 17, 2007 | 10:40 AM
cyclerage's Avatar
still need it
Old Oct 17, 2007 | 09:21 PM
kenp's Avatar
I emailed one to you from an 02 Z06.
Old Oct 18, 2007 | 08:17 AM
ZL1Killa's Avatar
why are you tuning the MAF? just use PE mode to get your fueling and then use VE to smooth all of your fuel trims....
Old Oct 18, 2007 | 10:43 AM
slow's Avatar
Maybe because that method is wrong.
PE is a commanded airfuel ratio function, if your commanding something other than desired your lying to the pcm somewhere in the calculation
Ryan
