02's and tuning Do you need 02's to tune a drag car with a sd tune? |
By having your O2s you don't have to be as picky or perfect (tuning) on the lower VE idle/driving regions, the computer will keep you at 14.7 Just spend more time tuning in the WOT areas. |
To answer your question. No you do not. If your engine has a large cam or open exhaust 02 sensors will give you phoney readings anyway. SD you are not using them anyway unless you are closed loop. |
I use the stock narrowband o2's to build the low rpm/part throttle VE table and the wideband for WOT. |
Speed Density = Not using MAF Closed loop = using O2 Open loop = not using O2 You can have combo's of the above like: MAF + closed loop = factory config MAF + open loop = using MAF but not O2 SD + closed loop = Not using MAF but using O2 SD + open loop = Not using MAF or O2 So I'll answer the original poster's question with a question.... Which setup are you using? Ideally you'd want a wideband to tune a drag car since the factory O2's are pretty useless at WOT |
| All times are GMT -5. The time now is 11:00 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
