02's and tuning
Old Oct 18, 2007 | 07:34 AM
Justa Z's Avatar
Default 02's and tuning
Do you need 02's to tune a drag car with a sd tune?
Old Oct 18, 2007 | 07:57 AM
Billiumss's Avatar
By having your O2s you don't have to be as picky or perfect (tuning) on the lower VE idle/driving regions, the computer will keep you at 14.7
Just spend more time tuning in the WOT areas.
Old Oct 18, 2007 | 04:22 PM
ChucksZ06's Avatar
To answer your question. No you do not. If your engine has a large cam or open exhaust 02 sensors will give you phoney readings anyway. SD you are not using them anyway unless you are closed loop.
Old Oct 18, 2007 | 06:15 PM
qqwqeqwrqwqtq's Avatar
I use the stock narrowband o2's to build the low rpm/part throttle VE table and the wideband for WOT.
Old Oct 19, 2007 | 01:43 PM
radkon's Avatar
Speed Density = Not using MAF
Closed loop = using O2
Open loop = not using O2
You can have combo's of the above like:
MAF + closed loop = factory config
MAF + open loop = using MAF but not O2
SD + closed loop = Not using MAF but using O2
SD + open loop = Not using MAF or O2
So I'll answer the original poster's question with a question....
Which setup are you using?
Ideally you'd want a wideband to tune a drag car since the factory O2's are pretty useless at WOT
