knock and timming
Old Oct 19, 2007 | 09:22 AM
dlove's Avatar
Default knock and timming
im fighting an issue with my car falling on its face only at the top of first.
Today i hooked it up to a snapon scan tool and checked out the timing and the the knock
in all gears at WOT the knock reads 4 degrees and pulls the timing down to 23
i was told the car was tunned to 26 then had 2 degrees taken out for nitrous.
So i unpluged the knock snensor and the timing stayed at like 35 or so and the car still fell on its face at the top of first.
AF is at 13/1 or so and fuel pressure is at 60psi
should the car be reading 4* of knock like that?
Old Oct 19, 2007 | 10:37 AM
SLP4CamaroSS's Avatar
send me your tune ill look at it
Old Oct 19, 2007 | 11:10 AM
dlove's Avatar
im going to get it loaded this weekend hopefully and i will contact you
thanks!
Old Oct 19, 2007 | 01:38 PM
radkon's Avatar
KR is bad mm kay, don't listen to anyone that says any different.
Get the timing right and you won't have any KR.
