speedo signal wire?
Old Oct 21, 2007 | 01:30 PM
DirtyBird222's Avatar
Default speedo signal wire?
Can anyone tell me where this is located or provide me with a diagram? I need to wire into it for the navigation on my new head unit, no one in the stereo and electronics section has been able to help!
Old Oct 21, 2007 | 02:14 PM
98turbls1's Avatar
What kind of vehicle is this on?? If F-body/GTO then it should be toward the back on the driver side... I believe it's a black plug... Or you may be able to hook into it at the PCM... You can verify the colors down below and then go to the PCM and make sure that it's the same wire (if it doesn't change somewhere which I have seen before)...
