codes
Old Oct 22, 2007 | 07:54 AM
SS 35TH's Avatar
Default codes
Installed a Speed alumin fuel tank in 2002 Camaro. How do I turn of these codes p0449,
p0452 with EFILive.
Old Oct 22, 2007 | 08:38 AM
ChrisS@sdpc's Avatar
Under 'Engine Diagnostics' you have the ability to completely disable the DTC's under the 'Processing Enablers' section or simply disable the MIL under 'MIL Enablers'. To turn the DTC test off, set the codes to 'X' under 'Processing Enablers'. If you want the tests to run, but don't want to see the MIL then set the same codes to 'No MIL' under the 'MIL Enablers' section.
