Need some code help
P0102 Mass Air Flow (MAF) sensor circuit low frequency
P0443 Evaporative Emissions (EVAP) purge solenoid control circuit
Definitely check the physical connections to the MAF both the air duct and electrical connections. A failing MAF (or one that is not connected properly)can cause all sorts of problems. The EVAP DTC is not too critical.
More reading:
P0102
P0443
HTH
