New gears on a C5, need to program?
Old Jun 11, 2003 | 06:15 PM
ElanMike's Avatar
Default New gears on a C5, need to program?
I am installing 4:10s on the Vette and have LS1 edit. Although it let's me adjust ratios, it says i don't have to on the Vette. Is this correct?
Old Jun 11, 2003 | 06:22 PM
minivette's Avatar
Default Re: New gears on a C5, need to program?
yup, I don't know how it does it but you don't have to reprogram. Kinda weird, huh?
Old Jun 11, 2003 | 07:16 PM
Bink's Avatar
joel(Bink)
Old Jun 11, 2003 | 07:20 PM
kp's Avatar
kp
The speed sensor on a C5 is at the output of the differential, it only changes if you change tire diameter. A camaro has the speed sensor at the output of the trans, so if you change the rear gear the driveshaft turns faster/slower..
