i need help with the predator
Old Oct 29, 2007 | 04:30 AM
m-knight's Avatar
Default i need help with the predator
i have a trans am ram air 2000 , ws6
and i bought the diablo predator
i found an option called obd
whats does obd means ,whats it used for and how should i adjust it for my ws6.
how can i use the spark how should i adjust it for my ws6, i have msd 8.5 wires in my ws6.
how can i increase the vaccum of air by using the predator
Old Oct 29, 2007 | 09:01 AM
01Z28M6's Avatar
I think the OBDII (on board diagnostics) is a menu that leads to a list of codes you can turn off. For example, if you want to eliminate the codes associated with rear O2 sensors, this is where you go.
Advancing spark timing usually gets you nothing but spark knock unless you understand what you are doing. As for the vacuum of air question, I think what you mean and want is for the car to breath better. This won't be done with the predator; you need to replace your intake and exhaust parts with better performing components for that. The predator has built in tune(s) to optimize your performance. You simply select the diablo tune for this. The option to adjust a tune requires you to know what you are doing and isn't designed for guess work. Diablosport has a technical forum where you can ask some questions that might lead to helping you get what you want.
