Injector swap from 28.8 to Accel 30#,which table in ls1edit?
Old Jun 12, 2003 | 07:28 PM
C4VetteLS1's Avatar
Default Injector swap from 28.8 to Accel 30#,which table in ls1edit?
Ok, im hoping for a simple answer because ive read through a few websites and they got me all twisted backwards trying to get the simple answer.
I swapped from 28.8lb @ 58 psi injectors to Accel 30# @
?43.5?lb injectors.
The correct table to change in ls1edit is the Injector Flow Rate table i believe.
So......... Accel 30# injectors are 34.64Lb/Hr @ 58 psi according to my calculation.
How do i figure what percentage to multiply the whole table??
which of these should i use:
30/34.64 = 86.6% or 34.64/30 = 115%
Can someone make sure i have my 34.64@ 58 psi correct because i think i have it way off
Old Jun 13, 2003 | 07:57 AM
Black LS1 T/A's Avatar
Moderator
Default Re: Injector swap from 28.8 to Accel 30#,which table in ls1edit?
Read this and download the Inj Flow Rate Calculator spreadsheet in the link there:
My Approach to Fuel Tuning with LS1-Edit
http://www.blackls1ta.com/LS1-Edit_Tuning.htm
Old Jun 13, 2003 | 03:28 PM
C4VetteLS1's Avatar
I downloaded that calculator before and is locked or something so i cant put the values in to get it to work right.
Old Jun 13, 2003 | 03:35 PM
C4VetteLS1's Avatar
Enter Your Current Stock LS1Edit Injector Table Below 100% Duty Cycle Reference Sample 98' 28lb F-Body LS1 PCM
KPA 0 5 10 15 20 25 30
3.62 3.64 3.66 3.69 3.71 3.73 3.75
KPA 35 40 45 50 55 60 65
3.77 3.80 3.81 3.84 3.86 3.88 3.90
KPA 70 75 80
3.92 3.95 3.96
New Injector Size Results- Enter into LS1Edit Injector Table 100% Duty Cycle
4.364768035 4.388882776 4.412997516 4.449169627 4.473284367 4.497399108 4.521513848
4.36 4.39 4.41 4.45 4.47 4.50 4.52
4.545628589 4.5818007 4.59385807 4.630030181 4.654144921 4.678259662 4.702374402
4.55 4.58 4.59 4.63 4.65 4.68 4.70
KPA 70 75 80
4.726489143 4.762661254 4.774718624
4.73 4.76 4.77
