Rev limiter whats it set at factory
In edit it says it's 6800. I am not getting there, no knock either. Just installed 2 new KR sensors. Sometimes I can get more rpms if I don't punch it, but where the fun in that.
I have a similar problem that is intermittent, and even though I replaced the TPS, I still get it from time to time.
My car will sometimes upshift early. Sometimes it will go from 1st at 3700 or so, to 2nd, then upshift to 3rd at aroudn 4600 or so. Then I get the shuddering from the motor trying to send the car down the track at the bottom of 3rd... very frustrating.
Sometimes, if it is in 4th or 3rd already, it won't downshift when I WOT, and I get that same lugging. KR factors in with that abnormal load, for me, too.
If I manually shift it, it goes, but when I upshift, it is not immediate, so I don't feel I have control of that situation either. I found if I wait til about 6000 RPMs and upshift, it will usually shift about where I put the shiftpoints.
More detailed info on my problem is here:
HELP! Short-Shifting out the hole - any ideas?
https://ls1tech.com/threads/showflat...o=&fpart=1
