Trouble Code p0300
Old Nov 10, 2007 | 06:30 AM
Mrjockos's Avatar
Default Trouble Code p0300
Plugged in my obd2 scanner, on my trans am 00 ls1, Got one trouble code, p0300 Random/Multiple Cylinder Missfire.
What could that be?
/Jocke
Old Nov 10, 2007 | 07:00 AM
vikingramair's Avatar
Sökfunktionen är bra prova den
(try the search engine)
Old Nov 10, 2007 | 03:34 PM
SSlow1's Avatar
I got the same damn code today
Old Nov 10, 2007 | 03:55 PM
edcmat-l1's Avatar
What could that be?
/Jocke
Could be:
Cracked plug
Plug wire not snapped on all the way,
Bad plug wire
Bad coil
bad connection at coil
Bad fuel injector
bad connection at fuel injector
Bent or broke pushrod
broken valve spring
broken rocker arm
Tune issue if you have a cam
etc, etc, etc......
Old Nov 10, 2007 | 04:06 PM
SSlow1's Avatar
what simptons can for Broken valve springs, Roker arm , or a bent rod???/
My luck it's one of those..........car was very hesitate ......idle is lil rougher....
car won't move it about 4000rpm's .......I have a 3200 Vig. stall just installed
Old Nov 12, 2007 | 10:26 PM
rotwiler's Avatar
Had that code when I put top engine cleaner in the engine and also a few months ago a mouse chewed one wire near my pcm harness. Fixed the wire and no issues. Look at the wires coming out of you pcm, never know.
Old Apr 15, 2010 | 07:33 PM
sprayin77's Avatar
I just fixed my problem with my misfire. I tuned it up 2 times and found a manifold leak and it cleared it instantly. So if u do a tune up and it doesn't fix your problem then check for vacuum problems.
