??Best method to keep the battery charged while editing??
Old Jun 17, 2003 | 10:48 PM
SSmokin 01's Avatar
Default ??Best method to keep the battery charged while editing??
I'm getting ready to start tweeking with edit.I just want to make sure I don't have any issues related to the battery dying on me during programming. I tried a search and sifted through quite a few posts but didn't find an answer.Thanks.
Old Jun 18, 2003 | 07:15 AM
99ZEOD's Avatar
Default Re: ??Best method to keep the battery charged while editing??
Your best bet is to ditch the stock battery and get an Optima. You'll never have a problem then.
Old Jun 18, 2003 | 10:39 AM
ChrisB's Avatar
There are issues with AC charges, in that the current put out by them tends to be "dirty". The safest bet is either to get a good battery, or if you want extra insurance get one of the 12V jump packs and hook that up.
Old Jun 18, 2003 | 11:04 AM
Cal's Avatar
Cal
This is very true; you would not want to be editing with a conventional charger hooked up. What I do is use the charger to top off the battery before I start editing, then unhook it.
Old Jun 19, 2003 | 05:56 AM
Gregg 00SS's Avatar
I usually hook up my charger, didn't know it was a bad idea. I hook that up to the battery and then run an ext cord for the laptop as to make sure that doesn't die for unknown reason. No problems so far.
Old Jun 19, 2003 | 06:37 AM
Plum Crazy Rob's Avatar
This is not like HPP. It only takes 2 minutes to program . If your battery won't stay up for that long you're not going anywhere anyway
Yanking the e-brake before turning the key on will disable the DRLs on a Firebird. Don't know what it does on a Camaro (which is funny since I have one ) , I know they have a different system. I'll try it tonight.
I'm usually more worried about the laptop BATTERY dying - maybe that's what you actually meant??
